CANT FIND MY 3D WORKING SPACE, USEING AUTOCAD 2019
PLEASE I CANT FIND MY 3D WORKING SPACE AM USEING AUTOCAD 2019.ANY HELP?
imadHabash
Hi and Welcome to AutoCAD Forum,
if you're preparing to draw 3d model ... i suggest to make your ViewCube active by NAVVCUBE (Command) . it's locate at upper right of your model space layout .
Imad Habash
mine is showing navv bar,and its on but i still can see my 3d working space
Alfred.NESWADBA
With a default installation...
  • You can find the list of workspaces available in the quick access toolbar (upper left).
  • You can also look to the lower right list of icons, looks like a gear-wheel, also this is a point where you can select the workspace you'd like to activate.
  • You can start command _WSCURRENT and enter 3D Modeling
  • You can start command _CUIX, in the list of workspaces select the item "3D Modeling" ==> right click ==> Set current.
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
