Cant disable searchable text in PDFs
dtiemeyer
Advisor Advisor
dtiemeyer
We have a government client who uses an archaic website that requires PDF's not have any embedded information, like bookmarks and text searchability.
When I configure my DWG to PDF.pc3 to 'Convert all text to geometry', and uncheck 'Create bookmarks', the resulting PDF's still contains searchable text as 'Markups'.
How can I disable this?
My other CAD is a Cadillac and I like to Revit to the Max!
kennyj
Hello @dtiemeyer,
From your Adobe PDF, open the file exported and Reprint to PDF.  Under the settings - default is Document and Markups.  Change this to Document only and print (with a new name).
This should remove the markup issue.
Hope this helps,
Kenny
imadHabash
would you please change PDFSHX ( EPDFSHX ) system variable to 0 ( zero) . then see if any changes .
Imad Habash
dtiemeyer
It would be nice if this was an option in the plotter settings, so that I could create 2 sets of plotter settings making it easier for my users to choose. But, thank you, this does control the behavior that I need it to. Cheers!
