Cannot use "ROMANTICITALY" style
f.r.1
Message 1 of 14
f.r.1
Hi everyone!
using ACAD 2017 i noticed it's quite impossible to use the style i want: if i select ROMANTICITALY from the drop-down menu, the text remains in STANDARD style.
This only from a PC, in the others i have, no problems
Replies (13)
Message 2 of 14
imadHabash
would you attache here your text style please with your selected text as a CAD drawing ?
Imad Habash
Message 3 of 14
ennujozlagam
Try to install the latest updates from Autodesk, sometimes it fixes the issues. Thanks
Message 4 of 14
f.r.1
Here the requested file.
Message 5 of 14
imadHabash
i open your CAD file and it's already used ROMANTICITALY style !!
please check from STYLE command that your font is active and not missed .
Imad Habash
Message 6 of 14
f.r.1
it is! also on my PC, but in the other one i have, the situation is this:
under windows font i have installed "Romantic", and also the other PC.
Romanticitaly should be a font, but a style
Message 7 of 14
alex101000
Font  romi___. Pfb installed on both computers?
In the absence of a font used in the aforementioned style, I get a message about replacing the font with one on my computer
Message 8 of 14
f.r.1
"Romy" is absent on both computers
Message 9 of 14
alex101000
In the absence of a font, a substitution message will be displayed.
What font is substituted? Is it the same on both computers?
Message 10 of 14
f.r.1
No warning windows. It seems nothing is missing
Message 11 of 14
pendean
Community Legend
Community Legend
Open your problem file.
QSAVE it.
Start ETRANSMIT command, ensure it is set to bundle everything (default setting), and continue with it.
Now open that resulting ZIP file: if you find the font file in there, you have it installed. if not, you do not so you need to go get it. Easiest way it is to do all the above at the other PC with "no problems", then drag and drop the font file into your own Windows Fonts folder (remember tor restart your AutoCAD afterwards).
Message 12 of 14
s.borello
Try manually dragging that font to where all your other Autocad fonts are... I forget the folder location but you can figure that out on your own... then restart your computer and see if it works.
Message 13 of 14
ara_neresesian
HI
-go to Text style
0,1 -make a new text style for  exmple" Romatic-it"
2-select to Romantic from font
3-select italic for style
4-set current (optional)
apply and close text style
select one text in model and now you can change the style from the properties box .
if something went wrong exit autocad and install romantic font
just in case see attached for romatic.ttf  font maybe you dont have it,click on font name after downloading,then r.click and select install ,
restart your autocad
Please select the Accept as Solution button if my post help to solves your issue or your question.
good luck
Message 14 of 14
f.r.1
I reinstalled the product and now i'm OK.
I think in the previous installation i didn't installed fonts, checking the tick
