Cannot trim hatch
Cannot trim hatch
dvrVSNMW
Message 1 of 13
Cannot trim hatch
dvrVSNMW
I cannot trim a hatch. Is there a way to trim this hatch ?
I attached a screenshot.
If you need more info pls ask.
Thx.
Replies (12)
Message 2 of 13
vinodkl
Check if the elevation of hatch and the line is zero.
Also check this: Click Here
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 3 of 13
dvrVSNMW
Hey, thx for the reply.
Elevations or Z-coordinates are all "zero"
Message 4 of 13
vinodkl
Have you checked the link provided above.
Message 5 of 13
dvrVSNMW
Now I have yes. No solution there.
I have made a new screenshot. The hatch has a circle in it, maybe this is not a normal hatch... ?
(for now I just have moved all the point from above to the line I wanted to trim on. So I fixed it the hard way.)
Message 6 of 13
vinodkl
You can share the drawing so that we can help you out with the problem.
Message 7 of 13
dvrVSNMW
Drawing in attachement...
Message 8 of 13
cadffm
Because the outline is garbage,
therefore the hatching has no calculated area value (see CTRL + 1)
Sebastian
Message 9 of 13
vinodkl
What @cadffm is telling is right.
A workaround would be to right click on the hatch and select generate boundary which would generate a boundary around the hatch. Now delete the hatch a recreate the hatch again. Now this hatch can be trimmed.
Message 10 of 13
dvrVSNMW
Yeah, hatch is ****ed up by the original "maker".  So I'll go with your solutions.
Thx everybody for the quick help!
Message 11 of 13
scot-65
Importing/converting a file from a media other than
AutoCAD based products for use in AutoCAD *might*
cause entity handling problems with hatch as well
as polylines, splines, arcs, etc.
Just be aware of this...
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Message 12 of 13
arpansark0544TCX
It can be trimmed if you do this.
Define a new boundary using Hatchedit. And then trim.
Note: Keep the newly defined boundary in the temp layer to avoid confusion.
I will work for sure.
Message 13 of 13
gpw800
Community Visitor
Community Visitor
change island detection style to normal
