cannot select plotter
Message 1 of 13
I cannot select my plotter, when i select it, it just goes back to "none". I've had a play around but nothing seems to work. Can anyone help?
When i use the same plotter from any windows application it works just fine.
Hide System Printers is untick
Replies (12)
Message 2 of 13
Alfred.NESWADBA
there are some questions open:
  • which plotter,
  • which plotter driver
  • which version of AutoCAD
  • which service pack is installed for AutoCAD
  • which operating system
  • did that plotter never work or was it working and something changed on your system
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 13
john.vellek
Hi @Anonymous,
Is this happening in all your drawings or just one?  I have run across this when a Layout has some corruption.
Have you tried recreating the PC3 file from scratch to see if it then behaves?
John Vellek
Message 4 of 13
I am not able tot select the root nor the PC3. Happens in all drawings.
Acad 2017
Message 5 of 13
Win 10
SP2
Plotter always working fijne.
HP
Message 6 of 13
imadHabash
I suggest to reset AutoCAD to default settings that it may help. >> Click <<
Imad Habash
Message 7 of 13
rkmcswain
This happens when you select a .PC3 file that references a system printer driver that you do not have installed.
Resetting your profile is not going to fix this.
See this also
R.K. McSwain     | CADpanacea | on twitter
Message 8 of 13
Alfred.NESWADBA
Well, if it was working fine, what changed on your system?
- alfred -
Alfred NESWADBA
Message 9 of 13
I wish i knew what changed. I never used a pc3 for this plotter. I'll try some suggestions made here. But now i am out of office for 17 days. I am also the only one at the office experiencing this problem.
Message 10 of 13
john.vellek
Hi @Anonymous,
I suggest that you try creating the new PC3 file when you return and post back to this thread with your results.
John Vellek
Message 11 of 13
Hi John,
Already tried that. Not able to create one on this plotter. As i said i never used a pc3 for this plotter.
Message 12 of 13
john.vellek
Hi @Anonymous,
It really sounds like the issue is with the Windows Printer driver. When you return, post back and perhaps we can coordinate a remote session.
John Vellek
Message 13 of 13
Great. I'll do that. Time for hollydays anyway
