Cannot select mirrored object
claudediehl
claudediehl
This one has been driving me crazy for quite awhile. I cannot select a mirrored object or text immediately after mirroring it. I can select the original entity that I mirrored, but not the new mirrored object. I have to perform a few other commands or switch layouts and come back in order to select the new object or text that I mirrored. Pickfirst is set to 1. Solve this and you'll be my hero.
CD
0 Me gusta
Responder
1.143 Vistas
19 Respuestas
Respuestas (19)
imadHabash
would you please attache here a little part from your CAD dwg for testing ?
Imad Habash
0 Me gusta
claudediehl
File uploaded. Thanks.
0 Me gusta
imadHabash
You know ... i'm afraid that when you mirror your text over the VP then you try to select them . you pick inside the VP and this is why you can not select the text .
Imad Habash
0 Me gusta
claudediehl
No, that is not what is happening. It happens anywhere in the entire drawing, on any and all drawings I work on.
0 Me gusta
imadHabash
any changes if you open the attached .dwg file ?
Imad Habash
0 Me gusta
claudediehl
Nope. Problem still exists.
0 Me gusta
Patchy
If you use REGEN right after mirror can you select it?
0 Me gusta
claudediehl
I cannot Patchy. I've tried all of the more obvious stuff. All I can do is move on and come back to it later, or switch between layouts real quick and keep working. It's a strange one. Been going on for quite some time.
0 Me gusta
RobDraw
Please share what you've tried. Maybe you missed something.
Rob
0 Me gusta
claudediehl
Obviously i missed something. :+} pickadd, pickfirst, cussing, screaming at the screen. Not necessarily in that order. There are posts about this issue from 15 years ago. Seems like its not something new. I have no idea what to do. I’m using ACAD2018. Maybe time to install the latest version. I have it, its just a royal pain to do it. As we all know.
0 Me gusta
cfindlay7MJ22
Can you, immediately after mirroring the object, select last object. If that works, then escape and try selecting it again by picking onscreen.
0 Me gusta
claudediehl
I can select the original object that I selected to mirror, but I cannot select the new mirrored object unless I change to a different layout tab and come back.
0 Me gusta
claudediehl
come back.
0 Me gusta
Kent1Cooper
@claudediehl wrote:
I can select the original object that I selected to mirror, but I cannot select the new mirrored object ....
I'm not sure, but I think @cfindlay7MJ22 was asking whether "Last" as a selection option succeeds in selecting the new mirrored object.
Kent Cooper, AIA
0 Me gusta
claudediehl
No, last does not work.
0 Me gusta
dbroad
I opened both drawings using AutoCAD 2019.  The first drawing posted had 11 errors and required recovery. There were also proxy objects.  I turned off the viewport to discover that all annotation was in the layout.  I checked display as plotted because yellow on white was giving me a headache.  I turned on the viewport and tried mirroring just about any annotative object. There was no problem selecting any f the resulting mirrored objects whether or not the original was deleted.  Could there be a memory issue at your end or a missing software update?  The drawings are relatively large for their content.  The purged version was half the size. The floor is oddly about 232' below the ucs world origin. I doubt any of that relates to your problem.  Do you have any third party customizations runing?
Just a thought.  If I'd left the objects at yellow, I doubt that I could tell that the objects were higlighted when selected.  Do you by any chance have your grip display off?
Architect, Registered NC, VA, SC, & GA.
0 Me gusta
claudediehl
Yellow on white is not my setting. That is your setup. My background is black. I am using Cadworx as well. And Recap files were part of this file before I removed them to upload it to here. Grips are on. And yes, all annotation is in the layout. On purpose. I get no errors when opening in Acad 2018. I did a full purge before I uploaded the file.
0 Me gusta
pendean
Community Legend
Community Legend
There is nothing wrong with your file or MIRROR commands in R2018.1.2 over here either.
But none of us are running CADWorx add-on either here.
Is your issue limited to this one file? If yes, are you able to run AutoCAD without CADWorx and see if your issue goes away in a new empty blank file?
0 Me gusta
claudediehl
Low and behold, it was a bug in Cadworx 2019. The issue has been resolved. Praise God. Thank you for everyone on here that reached out with your time, help, and ideas. Very much appreciated.
0 Me gusta
