Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
AutoCAD Forum
Cannot right-click print .DWG files - AutoCAD 2018
2 REPLIES 2
linksadmin
532 Views, 2 Replies
Recently updated to Windows 10, right clicked on a .dwg to print to PDF as I usually do, but there was no option to print to PDF, let alone to print at all. Tested all other file types and had no such issue. Seems to be limited only to .dwg files. Tried disabling the print to PDF feature, then re-enabled, and rebooted - no dice. Am forced to open up the .dwg files within AutoCAD and then print from within that. Though, this is, as one can tell, very time consuming, as before, I was able to highlight multiple .dwg files and print them all to PDF, simple as.
Would like any ideas. Found this previous forum post which seems to describe the issue, but attempting the Registry Editor fix did not work. Feel free to join in on this solution, AutoDesk employees.
Labels (4)
2 REPLIES 2
AdammReilly
in reply to: linksadmin
This is not a typical ability with a basic Autocad installation. Do you have a specialized pdf converter installed?
Something like Bluebeam or CutePDF, etc?
If so, perhaps one of those were enabling that conversion for you, and the upgrade disabled that function.
Adam Reilly
Dell Precision 55400
Windows 10 Pro
Intel Xeon E-2276M 2.80GHz, 64bit
NVidia Quadro T2000 Mobile/Max-Q
LinkedIn | Twitter
Group Leader badge
Austin CADD User Group
LinkedIn | Discord
RobDraw
Yeah, this is most likely a function of the PDF software rather than AutoCAD.
Rob
AutoCAD Inside the Factory
