Anuncios
cannot revolve object
No aplicable
Hello:
Thank you for helping me, I have one  more problem about "revolve". I tried to revolve the yellow object, and choose the yellow object at first, then I specifie two points on the red line so the yellow object can revolve around the red line, but it still not working? I re-upload the file.
What I did is that 1)type "revolve" in the commad 2)select yellow object and then enter 3) Specify two points on thered line and then enter. I don't know what is wrong with my steps? Can you please try to revolve the yellow object instead of building a new one because I am going to combine the object in layer 1 with object in layer 0 (I turned the layer 0 off)? Thank you so much!!!
Best!!!!
Edited by
Discussion_Admin
Responder
Soluciones aceptadas (2)
5.208 Vistas
4 Respuestas
Respuestas (4)
Sofia.Xanthopoulou
Hi @Anonymous,
you don't do anything wrong. Seems that the Spline is not accepted. Please explode the Spline object and revolve.
Regards
Please accept as solution if my post fully resolves your issue, or reply with additional details if the problem persists.
0 Me gusta
Alfred.NESWADBA
Solución aceptada
there are some points double in your spline (control point 19 and 20 as well as 1 and 2), these are critical situations and should be avoided.
At the moment you remove these 2 points command _REVOLVE will be happy to present you a valid result :cara_guiñando_un_ojo:
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
No aplicable
Thank you for helping me, i just do not understand how to check if my points are crossing and how to remove the additional points. In additional, I don't know how to check which points are 19 or 20 and 1 or 2?
0 Me gusta
Alfred.NESWADBA
Solución aceptada
Select the object then look to the properties Window, there you have the chance to step through the vertices/control points and every selected point gets a marker:
To step forwards and backwards use the small arrows on the left side of the field with arrow up/down symbol.
Start command _SPLINEDIT, select this spline, then use option Edit vertex ==> Delete
- alfred -
Alfred NESWADBA
