Hi, I have an issue here. I used AutoCad to do my M&E Services Coordination drawings and there is this particular problem that have just occurred and I don't know how to solve it. Appreciate if there is a solution.
My drawing consists of many blocks which I used to separate individual services. However, there is one block which makes me unable to print my drawing after I convert it to PDF. I can plot it directly from AutoCad but if I plot it to PDF and then print the PDF file, an error will occur and I cannot print it.
Even if I explode that block, I still can't print the drawing from the PDF file plotted. Only after I totally delete the block and whatever lines and text in it, can I print the PDF file plotted from the drawing.
Any idea what can I do? I absolutely must print the drawing from PDF format and I need the contents in the block.
Thank you.
