Cannot plot using Plot Area: Layout
rodrigo_luizp
rodrigo_luizp
I created a blank file and imported a titleblock i had.
Now i'm trying to plot using the option Plot Area: Layout.
But the drawing is all over the place depending on the scale.
If i set the scale 1:1 the preview shows blank
if i set the sacle 1:5 the preview shows drawing cut in half.
The plot offset is set to 0 everywhere, so why my drawing walking around?
And how do i center?
I cant figure it out!
(Sure i could use the option Plot Area: Window, but i want to learn how Plot Area Layour works and what is wrong)
Kent1Cooper
If you're plotting a paper space Layout, the plotting scale should be 1:1, not 1:5.  Do the scaling in the settings for the Viewport(s).
Kent Cooper, AIA
pendean
Community Legend
Community Legend
OR... delete your problem layout, create a new one: works just fine after that
rodrigo_luizp
I put scale 1:5 to show how it moved around on the plot preview.
But even setting everything to 1:1 it doesn't work.
rodrigo_luizp
Maybe the issue could be in some config on my computer?
I created a new layout as you suggested and it now shows a dashed pritable area and appears on the layout but doesnt fit quite right yet.
I fiddled with too many settings im afraid i broke something x).
paullimapa
Any reason you don't want to select Window area to plot instead of Layout?
Also your title block measures exactly A0 size at 1:1, why set the scale to 1:5?
There's a Center option in the Plot window as well.
Paul Li
IT Specialist
@The Office
rodrigo_luizp
The only reason im using layout, is that im trying to learn how to use that option. For pratical day use i always use Window mode. I put 1:5 scale just to see the effect of the change on the preview, but my goal was to make it work on the 1:1.
I gave on that quest, too complicated for me xD
