cannot flatten dwg file
danezeq
Message 1 of 15
danezeq
Hey
i'm trying to fltten an dwg file
i'm using the FLATTEN command.
the copmuter works hard for abount an hour and then i get the same Z axis lines. nothing changed.
Why is it happening?
Replies (14)
Message 2 of 15
Alfred.NESWADBA
To give a valid answer we would need:
  • the dwg-file to see which objects you have in your drawing
  • to know which version of AutoCAD you are working with
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 15
danezeq
Autocad 2018
File attached.
Message 4 of 15
Alfred.NESWADBA
for Polylines:
use command _QSELECT to select all polylines using a thickness > 0.0 and then change the property "THICKNESS" to 0
for block "Parcel-rh":
edit the block using block editor, run the same procedure as above for polylines and 2D-polylines
The rest was simply done by selecting all objects, then for each object type category change the corresponding value, e.g.
  • for arcs and circles ==> change center Z to 0
  • for lines ==> change start-z and end-z to 0
  • for polylines ==> change the elevation to 0
  • for blocks ==> change insertion point z to 0
Only attributes stay with that workflow at the previous position, ATTSYNC might help with that (losing the XY-position then, that's why I did not do that in your dwg-file)
- alfred -
Alfred NESWADBA
Message 5 of 15
danezeq
Thank you! i'm going to try this right now
Message 6 of 15
danezeq
i don't understand the trick. "thickness" is already set to 0 on properties.
here is what i did:
https://www.youtube.com/watch?v=lXLAimGQ0UE
Message 7 of 15
Alfred.NESWADBA
you selected all polylines with thickness = 0.0 and then verified the value in the property window ... please, select the polylines with thickness NOT EQUAL 0.0 and then look to the property window. 😉
- alfred -
Alfred NESWADBA
Message 8 of 15
danezeq
ok i did most of the things.
i dont find "insertion point" for blocks. does it has another name ?
Message 9 of 15
Alfred.NESWADBA
Please find it marked in the screenshot:
- alfred -
Alfred NESWADBA
Message 10 of 15
danezeq
Thanks, just found that 🙂
1.but a lot of blocks still has elevation. maybe its defined inside the blocks?
is there any way to flatten them all together?
2. how can i flatten "leaders"? when i pick them all, i dont see the "posion z" in the propeties bar...
Message 11 of 15
Alfred.NESWADBA
I guess you mean the attributes, that's why I wrote about command _ATTSYNC
- alfred -
Alfred NESWADBA
Message 12 of 15
danezeq
Thanks for all your help.
I kust learnd how to flatten in dwg file without the FLATTEN command.
Btw, why the FLATTEN command failed?
And another thing, whats the difference between thickness and elevation?
Untill today i tought elevation = Z axis value and thickness=lineweight. am i wrong?
Message 13 of 15
Alfred.NESWADBA
Needs to be answered by the developer.
From my side: the command was a tool (old one) to help for most situations, but can't help with all objects, especially these types of geometry introduced later than the tool itself was developed.
Have you looked to the help before asking? Just 2 links to these settings/properties:
>>>THICKNESS<<<
>>>ELEVATION<<<
If that is not well to understand then let us know that please.
First is correct, THICKNESS is the (3D)height of an object, not the lineweight.
- alfred -
Alfred NESWADBA
Message 14 of 15
danezeq
Thank you alfred. i learnd from you a lot.
Message 15 of 15
Alfred.NESWADBA
You are very welcome, - alfred -
Alfred NESWADBA
