Anuncios
Cannot Copy blocks to Favorites
spence7
spence7
A problem similar to Andrew's. While in the BLOCKS PALETTE, the Current Drawing tab, if I right click a block, the option to Copy to Favorites, is greyed out and unavailable.
I was really loving this option just a few days ago.
I copied that folder (C:\Users\cspen\AppData\Roaming\Autodesk\AutoCAD 2022\R24.1\enu\FavoriteBlocks - Copy)
right beside it-self to do a bunch of editing on the blocks and their names.
Now the Favorites tab in the BLOCKS PALLETTE is empty. Curious and annoying.
Help. Please.         Spence Ball,     Silver Spring, MD USA
0 Me gusta
Responder
Soluciones aceptadas (1)
887 Vistas
3 Respuestas
Respuestas (3)
Valentin-WSP
@spence7 ,
Check your file path in the Options > Block Sync Folder Location:
Try the suggestion provided on the help.
Also, take note:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
0 Me gusta
spence7
Tried that, but no. I could not quite get it to work.
But like so many things, a work-around was found.
0 Me gusta
spence7
Solución aceptada
My work-around is to load all my favorite blocks into the LIBRARY tab of the Blocks Palette instead of the FAVORITES tab.  For reasons hard to define I fancy the Blocks Palette over Tool Palette or design center.
Thank You.
0 Me gusta
