AutoCAD Forum
Cannot Convert DWG to PDF
3 REPLIES 3
4239 Views, 3 Replies
Hey,
I have been using autocad quite frequently lately and for some reason today I cannot convert my DWG files into PDF, although I have done the many times before. I have even tried opening old drawings to convert them to PDF and nothing will export. Please help!
3 REPLIES 3
Patchy
Use Windows System Restore, if it doesn't work, Repair your Autocad.
nestly2
Welcome to the Autodesk Forums
Are you using the PLOT command and using DWG to PDF.pc3 as your printer/plotter?
Alfred.NESWADBA
how do you convert DWG to PDF?
I would run command _PLOT or _PUBLISH (using the "DWG to PDF.pc3") and if you did it the same way we don't know anything about what's happening on your system! Do you get any error message, does AutoCAD crash, don't you get a PDF file, .... what is it that makes you thinking that "it does not work"?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Autodesk Customer Advisory Groups
