Cannot adjust hatch scale
laraujo
Message 1 of 20
laraujo
Dear sirs: I searched a lot, but could not find information on a way to adjust hatch scale. My hatches are always all white. I lowered scale and increased it without success. Thank you.
Replies (19)
Message 2 of 20
paullimapa
Share a sample drawing with this problem and specify the name of the hatch patterns you’ve tried
Paul Li
IT Specialist
@The Office
Message 3 of 20
laraujo
Thank you very much. It is a section on a concrete wall.
Message 4 of 20
paullimapa
no sample drawings attached & no hatch pattern name given
Paul Li
IT Specialist
@The Office
Message 5 of 20
Valentin_CAD
@laraujo ,
Try all the suggestions from this link:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 6 of 20
3wood
Delete and recreate the hatch.
Message 7 of 20
pendean
Community Legend
Community Legend
Someone else create that custom hatch for you, nd you do not have it on your system if you for example tries to use it in a new drawing. Correct?
OR... do you just need to thaw/unlock all layers, including layer 0 first, then try it.
Or the hatch is inside an XREF, or a block, and you did not notice yet?
Message 8 of 20
laraujo
Sorry, I thought that I had attached. Thank you.
Message 9 of 20
pendean
Community Legend
Community Legend
@laraujo where is the hatch please
Message 10 of 20
paullimapa
Since your area is such a small distance only a bit over 2 units your hatch scale value needs to be then very small as well...see attached dwg with the ANGLE hath pattern filled in the square next to your detail drawing
Paul Li
IT Specialist
@The Office
Message 11 of 20
laraujo
Thank you. Here is the drawing. You can see it, all white.
Message 12 of 20
laraujo
I set scale to 0.0001 without results.
Message 13 of 20
pendean
Community Legend
Community Legend
nothing attached.
Message 14 of 20
laraujo
[image: image.png]
Message 15 of 20
paullimapa
why so small...did you try 0.08 which is what I did in your drawing?
Paul Li
IT Specialist
@The Office
Message 16 of 20
paullimapa
Attached I successfully hatched your drawing showing name of patterns I used with their respective scales:
Paul Li
IT Specialist
@The Office
Message 17 of 20
laraujo
I tried 0.00001
Message 18 of 20
paullimapa
Why don't you do a screen capture showing the area you want to hatch and show us the name of the hatch pattern?
Also have you tried using one of the scale values I used successfully like 0.0025 for AR-CONC & 0.008 for GRAVEL?
Paul Li
IT Specialist
@The Office
Message 19 of 20
laraujo
Thank you very much. I just cannot do it. I attached the drawing with the hatch where it is supposed to be, put the scale to zero, and the hatch keep being solid.
Message 20 of 20
paullimapa
why you enter 0 when I told you to enter smaller numbers with decimal which works perfectly!!!
Paul Li
IT Specialist
@The Office
