cannot add plot style
lidan_zhangAUFKE
Message 1 of 9
lidan_zhangAUFKE
Replies (8)
Message 2 of 9
imadHabash
Type  STYLEMANAGER command. Add your style manger when the file explorer appear. Then It's recommended to restart your AutoCAD.
Imad Habash
Message 3 of 9
lidan_zhangAUFKE
It`s not working.
Message 4 of 9
imadHabash
Try from menu bar   File >> Plot Style Manager.
Imad Habash
Message 5 of 9
cadffm
1. The command is styleSmanager, it open winexplorer in folder with the wizard, you already found and started (Picture2)
2. Is it a new install?
3. The main question is: Why is your folder (open by using styleSmanager) is empty ?
    I guess this folder is empty except the wizard  -  .exe file?
    What is the folder name&path?
   If it is a new install, I would prefer to do a "Reset to default" and if it doesn't all the problems (I can't think the pstyle thing is the only one)
   Turn on win user admin rights, deinstall, reinstall.
_
4. Using wizard: Don't select 'Import from pcp/pc2 (Or did you upgrade from R14 and older?)
    Use "Start from scratch"
Sebastian
Message 6 of 9
lidan_zhangAUFKE
it's not working
and I try menu bar
Message 7 of 9
lidan_zhangAUFKE
  • After using the style management command, my document folder is opened. I don’t know what to do next, just like the folder popped up in the first step in the video.
  • Yes, I've reinstalled today, but the settings are the same as before
  • I got this path and it still didn't working
  • I try it,It's not working.
Message 8 of 9
cadffm
Sorry, everything is going wrong there.
 Because the path for plotter configuration path, is wrong
  also your plotystyle support path, is wrong
    and I guess a lot more is going wild
A.)
B.)
    deinstall,
C.)
    reinstall
D.)
   Start Acad and test / close Acad
E.)
   set your win user rights back to noemal.
F.)
   Start Acad and test again
3. >>"I got this path and it still didn't working"
     I asked about the folder-content. The Options/files/ you showed, is another support path - not for plotstyles
With Administration rigfhts? I can't image! Try it again, with admin rights and all Anti-virus programs off.
Or are you refering to this picture below? That's again not what I am talking about, this is the (reset) PROFILE,
I was talking about Reset AutoCAD! https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-reset-AutoC...
4. Use "Start from scratch"
I guess teh plot style wizard is much older and is not the right one for your version.
But this problem will fixed when you did a clean successful installation.
(Please make sure, NO wizard .EXE in your personal plot style folder / if present: Delete this .exe )
I like and prefer to start from scratch!
But if you like trying to fix the issues, here we go, set your support files:
Share a win-explorer screenshot of the content of the last folder ( support path for plot styles folder)
Are there standard .ctb and .stb files, + the wizzard link?
Sebastian
Message 9 of 9
lidan_zhangAUFKE
Thank you very much, I'll try again and tell you the results.😆
