Can you generate a plot file but have it saved / printed to a PDF rather than a plot file
steve_dininger
555 Visites
6 Réponses
Message 1 sur 7
steve_dininger
Community Visitor
Community Visitor
When generating a document using AutoCAD is it possible to generate a PDF file rather than a plot file? If I generated a plot file can this be opened by AutoCAD and then printed to a PDF
0 J'aime
556 Visites
6 Réponses
Message 2 sur 7
RSomppi
Yes, you can generate a PDF in a number of ways. Is that what you really want or do you want plot files or both? It's very hard to tell from your description.
0 J'aime
Message 3 sur 7
tboehler
Are you simply wanting to print to a DWG to a PDF from AutoCAD?  In the PLOT window select the "DWG to PDF" or one of the 5-built in PDF drivers.  You can also create your own custom plotter setups (ps3 file).
0 J'aime
Message 4 sur 7
RSomppi
@tboehler wrote:
Are you simply wanting to print to a DWG to a PDF from AutoCAD?  In the PLOT window select the "Microsoft to Print PDF".
Isn't the DWG to PDF driver a lot better?
0 J'aime
Message 5 sur 7
pendean
Community Legend
Community Legend
@tboehler if I may ask, why "Microsoft to Print PDF" and not any one of the 5-built in PDF drivers that behave way better?
0 J'aime
Message 6 sur 7
pendean
Community Legend
Community Legend
Greetings @steve_dininger
May I ask, are you unaware of the ab8ility to create PDF files in AutoCAD is built-in https://www.thesourcecad.com/how-to-print-autocad-drawing-to-pdf/#:~:text=To%20plot%20a%20drawing%20....
and you can use PDFs to print to any paper service later?
Or is there something you forgot to add to your post?
0 J'aime
Message 7 sur 7
paullimapa
if your plt file is generated from a printer driver that creates following formats: HPGL, HPGL/2, HP-RTL and KIPGL then ViewCompanion can even batch convert multiple PLT files to PDFs.
Paul Li
IT Specialist
@The Office
0 J'aime
