Can we do "dwg Compare" without considering Xrefs
zirudezirude
zirudezirude
Hi Guys,
I want to compare drawing "A" to drawing "B", so I opened the "A" and unloaded all Xrefs,
drawing "B" contains Xrefs,
is there any way to compare "A" to "B" without including "B" Xrefs in the comparison?
imadHabash
I'll give a hint that will meet your needs :
  • If you have a layer that is turned off or frozen in your current drawing, it will not become part of the comparison result.
  • If the comparison drawing is also open, any changes you make in the comparison drawing do not display in a comparison until you save the changes.
honestly... I have not test the second hint. BUT you can try to unload the xref's then save your CAD dwg's and check if it's ok.
Imad Habash
