Can't use OVERKILL, it doesnt delete overlapping lines
I recently have this problem when i exported my .skp to .dwg file, it has so many overlapping lines but when i do the OVERKILL command it just wont work.
Ive tried to do anything mentioned in this forum, such as exploding it, using FLATTEN command, modify the tolerance, etc. but it just won't work.
Ive attached my .dwg file down below, please analyze it and let me know if i do something wrong
Thanks before
Alfred.NESWADBA
Please, be so kind and tell us where we have to look for the doubled lines. Your drawing contains 20000 lines and I don't have the time to analyze such a mass of lines to find the doubled ones you are referring to.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Alfred.NESWADBA
Just as additional note:
starting _OVERKILL with the settings shown in the following screenshot deleted 14000 objects ...
- alfred -
Alfred NESWADBA
ennujozlagam
try to copy and paste in a new drawing file and use overkill command and see if helps. thanks
Check the attached dwg & see if this is what you are looking for
see attached png for overkill settings
I used recover to open the file (no errors)
I used pedit using multiple option, and converted lines & arc segments to polylines
Then used overkill with the settings shown
then ran audit & purge before saving/closing
Hope this helps
