Can't sign in to A360 from AutoCAD 2017
Message 1 of 57
Ever since installing 2017 I can't sign in to autodesk in the program. I type in the correct username and password and it signs me in for a second then immediately brings back the sign in prompt. I need to use geolocation services but I can't unless I'm signed in. I have tried using a different email to make a new account and that one does the same thing.
@Anonymous,
john.vellek has edited your subject line for clarity:Autocad won't let me sign in.
Replies (56)
Message 2 of 57
rkmcswain
Sounds like an issue on your end. Firewall, port blocking, etc.
Is this an office environment? Can you connect to the Internet through some other means temporarily to test?
Message 3 of 57
I'm in an office and everyone else is able to access geolocation and sign in, but I cannot. I can access the internet fine, it even signs me in for a brief second and then immediately signs me out. The sign in "bar" at the top of the window flips to show my username and then flips again to say "sign in." Every time I sign in it does this.
Message 4 of 57
wispoxy
Hello @Anonymous. If someone else close to you signed into Autodesk using geolocation under the same place, you can't login again. Using a computer with multiple user accounts and someone staying logged into autodesk, is also an issue.
I forced the user to disconnect from autodesk by unplugging the network for atleast a good 3-5min. Unplugged from the router. It should trigger an auto logout from autodesk.
Message 5 of 57
We all use different accounts and have different licenses and were able to use geolocation simultaneously in the past. My larger problem is that I am not able to sign into autodesk 360 in order to access my settings and use geolocation.
Message 6 of 57
wispoxy
Make sure you're even allowing access to geolocation. You don't need to be logged in to allow geolocation, set your computer location settings. Not much different than using A360 on iPhone.
Message 7 of 57
I would also like to be able to sign in to autodesk 360 regardless. And how would I go about enabling geolocation?
Message 8 of 57
wispoxy
What operating system are you using?
Message 9 of 57
Windows 7 professional 64 bit
Message 10 of 57
wispoxy
Ahh... Autodesk 360 only works with Microsoft 8 modern mode, it can not longer work in Windows 7 or earlier. Recently changed.
Message 11 of 57
That is not true. All my coworkers are able to use it and they operate on the exact same machine as I do.
Message 12 of 57
You may have misunderstood me. I just want to sign in to autodesk on AutoCAD 2017. That is all I want to do and I am unable to do it.
Message 13 of 57
wispoxy
Please screenshot what you're trying to sign into.
Message 14 of 57
I'm trying to sign into Autodesk.
Message 15 of 57
wispoxy
That is Autodesk 360!!!
Message 16 of 57
I'm sorry, but you are saying that is impossible for my coworkers to sign in to autodesk on Windows 7? If so then we have some miracles in my office. I don't think you are going to be able to help me, but thanks for trying. I really do appreciate you trying to help but I think I would like someone else's advice on this.
Message 17 of 57
wispoxy
You cannot sign into Autodesk 360 through AutoCAD anymore with Windows 7. Sign into Autodesk 360 with Windows 7 through a browser.
Message 18 of 57
That is not true.
Message 19 of 57
wispoxy
Message 20 of 57
I have about 5 other people in the same room as me right now signed into Autodesk in AutoCAD right now and all are using Windows 7. If we are referring to the same thing then you are mistaken.
