can't select vertex while using dimangular
DanielkrampenV8756
DanielkrampenV8756
Thanks in advance to everyone for your help. I am using autocad 2016. I am attempting to show a dim angle at greater than 180 degrees. I understand the way to do this is to select the vertex and then select the end points. When I select dim angular it doesn't allow me to select the vertex. Is there something special I need selected under snaps or something? Thanks again.
0 Me gusta
Responder
Soluciones aceptadas (1)
712 Vistas
3 Respuestas
Respuestas (3)
No aplicable
Post your dwg.
0 Me gusta
DanielkrampenV8756
I can't the flash part is blocked by the antivirus.
0 Me gusta
DanielkrampenV8756
Solución aceptada
I figured it out. If I right click it allows me to then select the vertex.
0 Me gusta
