CAN´T SELECT MORE THEN ONE OBJEKT AT A TIME
Torben.pedersen
Torben.pedersen
Hallo there
I can´t seem to select more then one objekt when I need to copy.(It¨s only when copying, not move.)
I have tried the following things:
1. PICKADD = 1(also 0 and 2) does not work
2. go to OPTIONS
* Click SELECTION tab.
* Under Selection Modes, UNCHECK the "Use shift to add to selection" box.
Does anybody have any other sugestions?
Mvh Mads 🙂
I hope this was helpfull.
Did I answer your question please accept this as solution.
if you liked my answer feel free to give me a Kudo 🙂
Alfred.NESWADBA
so while no command is active you can select more than one object?
What happens when you start the copy command using that syntax (typing in the command line):
_.COPY
(including underline and point) ... does that allow more than one object to select?
When you start your copy command, select one object and before you want to select the second one ... what does the command-line show? Does it show "Select object: " or anything else? Maybe a screenshot could help.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Torben.pedersen
somehow it work now, and I don´t know why.
I could select more then one object, when I then clicked on copy it deselected what I had selected, ant then I could only select 1 object. it showed Select object in the line
Alfred.NESWADBA
Sounds like PICKFIRST is not set to 1
But then this problem would also appear with the move command (not just the copy command), so again:
Select two objects, and instead of clicking anywhere to start the copy command type (with the keyboard):
_.COPY
What happens now?
- alfred -
Alfred NESWADBA
Ajilal.Vijayan
This will happen if the PICKFIRST is set to 0.
Try after PICKFIRST and PICKADD set to 1.
