Anuncios
can't scale drawing to 1:250 for printing
n_nhaery
n_nhaery
hello, i have a 1:1 siteplan that i drew with meters as the units. i need to print at a 1:250 scale, however whenever i try to do so in the layout tab, it is incredibly small even on a 11" x 8.5" paper. i'm not entirely sure if i'm doing something wrong, or if it's the scale i am using. i have attached the dwg file if that is helpful. thanks!
0 Me gusta
Responder
Soluciones aceptadas (1)
307 Vistas
7 Respuestas
Respuestas (7)
paullimapa
Since you're drawing in Meters in Model but your Layout is using units in Millimeters then this is your ScalelistEdit factor for 1:250:
To see more of your large site plan I would use 1:1000 then your ScalelistEdit factor would be this:
Paul Li
IT Specialist
@The Office
0 Me gusta
richard_387
I think you should be using a scale of 1 to 2500.
At a scale of 1 to 250, you would not get your scale bar (lower right hand side of drawing) onto an A1 sheet.
paullimapa
I think you are correct to see the entire site at 1:2500 @n_nhaery
Paul Li
IT Specialist
@The Office
0 Me gusta
n_nhaery
thank you, i'm testing out the 1:2500 scale as you showed in your message, mine isn't filling the A1 page. have i done something incorrect in the provided screenshots? i do need the siteplan printed on a page size that adequate for drawing over with tracing paper. thank you again.
0 Me gusta
paullimapa
Solución aceptada
As I responded previously, setup a layout for each different scale instead of changing the PLOT window's scale...leave that at 1:1
Paul Li
IT Specialist
@The Office
0 Me gusta
n_nhaery
perfect, greatly appreciated, thank you so much!
0 Me gusta
paullimapa
you are welcome and thank @richard_387 for contributing to the answer...cheers!!!
Paul Li
IT Specialist
@The Office
0 Me gusta
