Anuncios
Can't plot the grid!
No aplicable
Why can't Iplot the grid?
Its frustrating that all of a sudden I have to set up the grid in every single viewport but I ahve done that. It just doesn't print. Why oh why? I really need the grid and now I am going to have to manually draw a grid. *tears*
0 Me gusta
Responder
Soluciones aceptadas (1)
5.966 Vistas
18 Respuestas
Respuestas (18)
No aplicable
Solución aceptada
If your talking about the display grid, it is not comprised of entities and will not plot.
0 Me gusta
Alfred.NESWADBA
Because it is a virtual element like the cursor is it too, the cursor can't be plotted as well.
If you need a raster for plotting you have to create it with "real" geometry, In case of GIS (Map 3D or Civil 3D) you also have special functions for viewports like command _MAPLAYOUTREFERENCESYSTEM.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
0 Me gusta
*handing over napkins* since when were you able to plot the display grid, the one you toggle On and OFF with F7? You can snap a screenshot and it shows but that's about it. Or are you thinking about Excel instead?
0 Me gusta
No aplicable
The GRID display has never been able to be plotted in AutoCAD.
You are talking about the grid that can be turned on/off with F7?
0 Me gusta
No aplicable
If drawing a grid in ACAD brings you to tears, maybe it's the wrong software for you.
Kent1Cooper
I agree with what others have said.  Additionally....
If you want a grid that will plot, drawing one has distinct advantages over having the display/reference grid plot.  You can draw it at the spacing(s) you will always want it to plot at, then you can change the density of the reference grid, and/or turn it on or off, and/or change its origin point and/or rotation, as much and as often as you want, without risk of differences in the plotted grid in different plots of the same drawing.  You can have it be made of any linetype you wish [CENTER would be very appropriate in a lot of applications], even in different linetypes for different lines in it, or different lineweights and/or linetype scales and/or colors for some, to emphasize or de-emphasize them.  It can be masked with Text Masks or Wipeouts, or Trimmed away, around things you don't want the grid lines showing through.  You can make a radial/circular grid if that's appropriate.  You can absolutely control the extent of it, to any size or shape outline [not just the rectangular drawing limits].  You can have different grids in different areas of the same drawing or view.  Etc., etc. ....
Kent Cooper, AIA
0 Me gusta
No aplicable
Thanks for all the replies.
The new version apparently allows you to set the viewport grid separatley from he model space grid, cool, but it would be cooler if new viewports would automatically match the model space instead of some random default.
Also, why have grids specifically laid out in the viewport on a LAYOUT if you can't also print them?
I did manually draw my own and I have yet to get it to print. In addition, when my boss says quickly print this with an entirely new grid layout it would be cool to be able actually do it quickly!
I doubt I would ever need a radial grid, unless I go work in Antarctica, which is more doubtful. So I would just like to be able to use the built in grid.
The tears were because I had just spent hours trying to figure out why printing has changed and trying to get things to print right for the meeting this morning. This was at 7pm (I was meant to be home by 5pm). And I don't think you know how many grid lines and manual dashed lines I had to draw!
0 Me gusta
No aplicable
Alfred, that's helpful thanks. But small problem; I can't chose the correct scale and I need a different precision than the ones listed (50m instead of 10 or 100). How do I change that?
0 Me gusta
Alfred.NESWADBA
When I start the command after selecting the viewport I get a dialog which ask's me about which type of coordinates, the scale of the viewport and the density, don't you get that?
(sorry for German dialog, should at least look equal to the English one except the text)
- alfred -
Alfred NESWADBA
No aplicable
Yes that's it. So under MaBstaub I get 1:40000 among other large scales. My map is 1:400.
Under Genaugkiet I get a list of multiples of 10. But I need a 50m grid.
0 Me gusta
Alfred.NESWADBA
Maybe I understood the question not correct:
The values listed are just some default suggestions ... you can type in any (numerical) values you like.
- alfred -
Alfred NESWADBA
0 Me gusta
No aplicable
Oh, yes, I can type in any scale. But not precision. Can you type in your own precision?
0 Me gusta
Alfred.NESWADBA
I can type in both values, look to the video:
Tested with Map 3D 2015 and 2016.
- alfred -
Alfred NESWADBA
0 Me gusta
No aplicable
Emoticono frustrado I can't. Weird. And frustrating
0 Me gusta
No aplicable
PS what do you use to create that gif?
0 Me gusta
Alfred.NESWADBA
Some questions:
  • What version of Map 3D do you use?
  • What service pack have you installed?
  • Does that also be blocked when you try that with a new drawing?
  • Can you upload the drawing (at least with that layout and viewport) which does not allow to set that by keyboard-override?
This app: >>>Camtasia Studio<<<
But to record the screen you can also use the free >>>Autodesk Screencast<<<
- alfred -
Alfred NESWADBA
0 Me gusta
No aplicable
I thought I had replied here but basically I found that the type of grid you choose is important. I had to choose "Current map reference system"
But it doesn't work because I get a grid that is way out. I thought that surely "Current map reference system" would match my current grid?
0 Me gusta
Kent1Cooper
@Anonymous wrote:
.... when my boss says quickly print this with an entirely new grid layout it would be cool to be able actually do it quickly! ....
[Yes, years ago, but I was brought here by a Search to get something to link to, in reply to a new topic on the same question.]
If you draw a grid as a User-defined Hatch pattern with the Double-direction option, changing its scale factor for the spacing, and if necessary its origin, is near-instantaneous.
Kent Cooper, AIA
0 Me gusta
