Can't Join spline and arcs
Karol-Or
Karol-Or
Although they all look planar.
Also why is the z=34.... for the lwpolyline in the Properties, but z=0 in List?
0 Me gusta
Responder
702 Vistas
2 Respuestas
Respuestas (2)
neaton
The UCS has been moved to a point on the pline . When you type UCS at the command prompt it says "NO NAME". Notice where the UCS icon is.
When you change the USC back to "WORLD" the UCS icon moves to 0,0 and shows where the pline actually is.
For more on the UCS check out the >>UCS Knowledge Base<<.
Nancy
0 Me gusta
parkr4st
I opened your dwg
a new layer current and BOUNDARY, click inside your work and the boundary is made indicating all your work is on one plane.
UNDO that
I find two polylines and two arcs,  no splines
JOIN joined and converted into one closed spline
are you asking about the Normal Z of negative value in properties?  some explanation in these posts.
https://forums.autodesk.com/t5/autocad-map-3d-forum/normal-z/td-p/636762
https://forums.autodesk.com/t5/autocad-forum/normal-z/td-p/6484069
dave
0 Me gusta
