Can't insert block Autocad 2018.1
No aplicable
08-02-2017
12:49 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I have a problem: with Autocad 2018.1, if I try to insert (on a new drawing) a block created with another program (BricsCAD) Autocad (Italian 64 bit version) returns the following errors:
Original message:
Comando: _INSERT
Errore operazione di modellazione:
Error Code Number is 30015
*Non valido*
Translated version:
Command: _INSERT
Modeling operation error:
*Invalid*
and does not insert the block.
These blocks, however, are inserted without problems in previous versions (Autocad 2015 and 2016)
I attach a sample block to the problem described above
What can I do?
(Sorry for the bad English)
