Can't get Hatch to work
No aplicable
I'm not sure why, but I can't get this particular hatch to work. It used to work fine, but now it simply won't show up. I've tried it in different drawings, different layers, different scales, tried downloading it again from the source (http://micastoneworks.com/resources/hatch-patterns). Not sure what is wrong.
Attached is the pat file and a video. I'm using AutoCAD LT 2019.
Please help! Thanks.
0 Me gusta
Responder
Soluciones aceptadas (1)
624 Vistas
3 Respuestas
Respuestas (3)
Alfred.NESWADBA
Solución aceptada
can you open my drawing and do you see the hatch pattern now?
If you try to add new hatches in this/my drawing, does it then work?
Make sure you have set HPMAXLINES to 10000000
If that does not work in your dwg-file, then please upload your dwg-file so we can look into it.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
No aplicable
That worked. You're the best, thanks!
0 Me gusta
vanessa.smullen
Community Visitor
Community Visitor
Thank you!!
0 Me gusta
