Can't draw line via length, only via absolute coordinates.
EDIT: I have solved the problem, but I do not understand why or how this happened or why what I did fixed the problem. Anyone who cares to shed light on this so I can avoid it happening in the future, please do.
The solution: I turned endpoint snapping ON then OFF again, and the problem resolved itself.
My original post:
Using 2022 version. Completed several models in draft mode, converted to 3d, etc. No issues.
Today I opened up my completed models, and I am unable to draw lines in ortho mode by entering the length. It only gives me an option to enter absolute coordinates. Have been googling for about 4 hours, can't find a single person that's even had this issue. (Maybe I'm not using the correct terms)
When creating a new blank drawing from the default cad template that comes with the installation, and I create the FIRST line, I am able to enter the length as expected. However, when I start the line by snapping it from a nearest point on another object, the option to enter length disappears and I am left only with the option to input absolute coordinates.
Actual program behavior:
It's probably something very basic.. Greatly appreciate any assistance!!
cadffm
You can use absolute or relative coordinate like you want whenever you want
#0,0 absolut @relative
But what you are searching is the default methode in dynamic input: DYNPICOORDS, read the [F1]Help about it
Sebastian
mgarcesUX9HW
Hi it could be that you turn off the "dynamic input" pressing F12 key will toggle on and off of the dynamic input
vladimirvay
Press F12.
