Can`t copy/paste layer
I am trying to copy some objects from one drawing to another. Тhe objects are copied but not the layers they are into.
I am currently working on AutoCAD 2014.
 Thank you in advance !
ilia.borisov
From what version are you trying to copy
Mechanical
imadHabash
i suggest to follow this link that may help you to fix your issue . >> Click <<
Imad Habash
Alfred.NESWADBA
So you draw a line on layer "A" ... then you use copy & paste to copy the line into a new drawing ... which layer does this line now is assigned to?
And to clear up some things:
The message you showed in your first post appears when exactly?
Are you now using AutoCAD 2014 or AutoCAD Mechanical 2014?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
pendean
Community Legend
Community Legend
Your posted screenshot says your 2014 file was last opened in 2018 or newer and got saved there: this makes all AEC content out of reach to your older 2014MECH variant forever.
Did you (or someone) take the file home to work on in 2018 or newer?
