Anuncios
Can't convert surface to solid, watertight issue.
No aplicable
I'm having trouble converting this surface to a solid.
The error seems to be that the surface is not watertight.
Can someone help me with this?
Thanks.
0 Me gusta
Responder
Soluciones aceptadas (2)
6.173 Vistas
8 Respuestas
Respuestas (8)
imadHabash
Solución aceptada
Hi and Welcome to AutoCAD Forum,
>> I'm having trouble converting this surface to a solid. <<
i suggest to try THICKEN command . put proper thickness value and your model shape will convert to 3d solid .
Imad Habash
No aplicable
Is it possible to convert it into a solid block without it being hollow inside?
I have tried the thicken command but I'm having trouble to make it into a whole solid block.
Thanks.
0 Me gusta
Alfred.NESWADBA
Error message seems to be correct (same on both sides):
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
No aplicable
Thanks for helping me find the gap, I have tried several ways to patch it but to no success.
I'm trying to make it into a solid block.
Thanks.
0 Me gusta
Alfred.NESWADBA
Solución aceptada
you might start a different way: start with a simple box (with the size of extents of your object).
Then run command _SLICE with your curved surface.
Good luck, - alfred -
Alfred NESWADBA
No aplicable
I tried to Slice the curved surface but it gave me this error: SLICE failed for selected solid.
EDIT: Added attachment.
0 Me gusta
No aplicable
Turns out the grid lines I used to make the curves before surfaces was very slightly misaligned, which causes it to not form a watertight surface.
I re-did it with a solid block this time and thickened the surfaces before subtracting it from the block. Then used a series of union and subtract and formed what I wanted.
Thank you all for your help!
0 Me gusta
Alfred.NESWADBA
great, good to know it's working well now for you!
Thank you for your feedback!
- alfred -
Alfred NESWADBA
0 Me gusta
