AutoCAD Forum
Can't close block editor
38 REPLIES 38
Message 1 of 39
68411 Views, 38 Replies
AutoCAD 2010. I was editing a block in the block edit screen and it wouldnt save the block. My screen froze and I had to reboot the computer. Now when I open the drawing it is still in the block edit screen and I cant get out of it. Help!!!!!!!!!!
38 REPLIES 38
Message 21 of 39
doni49
in reply to: dmfrazier
When you checked Drawing Recovery Manager, did you see an Autosave file there?  Although it's been long enough that it might very well have been overwritten.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
Message 22 of 39
in reply to: doni49
There was a bak file there it was the same way as the original drawing.
Message 23 of 39
sthompson1021
in reply to: doni49
Hi, I hate to be the bearer of bad news but once you hit save when you rebooted, you wiped out your previous autosave files. If you are working on a network and they backup files everyday, maybe you can get a copy from the day before the problem started.
Message 24 of 39
in reply to: sthompson1021
Yeah. Small company everything is on my computer only and thumb drives
Message 25 of 39
Dear jay, Today i also find same problem with my Autocad 3D Civil 2012 and it's solution is very simple. Type command in Command bar "Recover" then choose that file and recover file as model. Regards, Sushil Kumar
Message 26 of 39
yeah!!  above comment that helpful
i got a same problem and i try many way ...
 Now  just type command     " recover "   and then press  1 file its came back and save as to the new file name....
Many thanks
Message 27 of 39
in reply to: doni49
 DONI49, Thank you so much, you are the best:
Correct,  I was in Model space and edit an enhanced attribute block, then I did all above and could not close upper toolbar with Close Block Editor, xref layer was locked, but still after unlock did not solved the problem;
This was the key:
Type in: DRAWINGRECOVERY
Message 28 of 39
matt
You're obviously not familiar with this blog.  You have to go on and on about something to show how smart you think you are, and then make sure that what your write doesn't accidentally have something to do with the question the person is asking.
Here's an example.  After I post "I cant close the block editor"  you could say "What kind of machine do you have Matt? "  Then I answer "A two year old dual 6 core  linked server grade with a solid state drive.  Works about 24x as fast as a dual quad core (which is what I have and occasionally people will say maybe it's my computer)."
 Then you reply "Oh, I see.  Have you tried changing out your video card?  Try that and then get back to me."
Your response was the first one I came to, was only a few words long, and was exactly the fix I needed.  That's not acceptable.
Message 29 of 39
cadffm
in reply to: matt
deleted
Sebastian
Message 30 of 39
Right click "close xxx" either block editor or reference edit.
Message 31 of 39
izwan.me
thanks bro.. its really help,...Heart
Message 32 of 39
RobDraw
in reply to: matt
What?
Rob
Message 33 of 39
in reply to: RobDraw
Right click in empty space and select Close Block Editor from the menu.
Message 34 of 39
in reply to: doni49
any updates on this problem, i am encountering the same thing
Message 35 of 39
RobDraw
The issue is marked as solved. I wouldn't expect any updates.
Rob
Message 36 of 39
CARLOS.RENDONR4QLN
I had the same issue where the block editor would not close.  I clicked on the close block editor button and nothing happened. I typed _bclose and that didn't work.  I tried a couple other suggestions in this thread and still the block editor would not closed.  I tried another Google search and the 2nd link down mentioned bsave.  That did the trick for me.  Wish I would have checked the first time it happened, I lost so much information that time.
Message 37 of 39
Rambazamba73
bclose command ?
Message 38 of 39
ahankermeyer
No solution yet?!  I'm having exact same issue.
Message 39 of 39
In block editor, try the command "BSAVE".  That worked for me.
Forma Design Contest
