Hi guys
I've recently come up against a problem when using AutoCAD - never have I had this problem. After having spent hours of searching on the forums and miscellaneous sites. I still couldn't find any help.
So basically, I'm drawing a house, as I'm a carpenter student. I've to draw a LINE to create a 30 degreed rafter. It won't let me pick the length, hit tab, or choose an angle. I've seen maxim_k post this:
- start LINE command
- pick first point, than hit Tab key, than input angle
- than hit Tab key again - the line will be constrained to the angle you input in previous step
- than input line length and hit Return or Spacebar.
I have Dynamic input turned ON, but it still won't let me do it.
