can't bind or insert xref
I use autocad 2014 student version. can't bind or insert xref into the current drawing. The command line shows that "xref file is currently not found. reload or detach before binding".
I reload the xref, but shows up with the same hint,
Is it a function limit of the student version or something else is wrong? Thanks
imadHabash
i suggest to follow this AKN article that it may help.
Imad Habash
oswaldodcb
Hi @Anonymous!
That could means that one of the other XREFs is referencing it. You need to go into the XREF file that has it as a reference and bind or detach the from there. Save the file and the reload it in the base file. You should be able to bind it.
I attached this link so that you can check information about linking external references:
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/beta/CloudHelp/cloudhelp/2015/ENU/AutoCAD-Core/files/GUID-A987D2FF-45BD-474E-99C1-E6316A42F667-htm.html
Oswaldo Caballero
Project Engineer / Autodesk Certified Instructor / Autodesk AutoCAD Certified User and Professional
Maracaibo, Venezuela
LinkedIn
Da un Me Gusta si la publicación ha sido de utilidad y si ha resuelto tu duda presiona ACEPTAR SOLUCIÓN
Was the file previously attached and then erased??
Is it nested in another file??
Is it nested in another file where it has been attached and then erased??
john.vellek
Hi @Anonymous,
When you open your External References Manager palette and select the XREF, it will show the saved path. Check to make sure the file exists in this location. If it doesn't go to the Details section and click on Saved Path. At the right there is an ellipsis. Click it and navigate to where the file now exists.
John Vellek
john.vellek
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
Hi.
I just follow your guide and it works for me.
Thanks!
