Announcements
Can only see objects after selecting them
 How can I fix this situation where I cannot see objects unless I select them? (with CTRL+A)
UnselectedUnselected
SelectedSelected
Replies (8)
imadHabash
you may check settings from OPTIONS
Imad Habash
Those settings didn't help.
Only in a specific file I cannot see some of the lines unless I select them with CTRL+A.
imadHabash
n
Imad Habash
j.palmeL29YX
Would you please upload an example file (dwg) with some representative objects (some which are always visible some of the "ghost" objects. The others you can delete.
cadder
Jürgen Palme
I've attached the file.
j.palmeL29YX
I found 2 WIPEOUTs at Layer "reka". This wipeouts hide the "invisible" objects.
You must decide what to do with this wipeouts. (delete or move or freeze layer reka or ...)
cadder
Jürgen Palme
Thanks.
I used command "WIPEOUTBORDER" (1) to find the wipeouts easily and then deleted them.
