Can not select whole object ( a square) for offset
limlimlimmy
limlimlimmy
I clicked on the offset, click on the object ( a square)  than type the distance. However, I can only offset one side of the square instead of the whole 4 side of the square.
0 Me gusta
Responder
1.294 Vistas
3 Respuestas
Respuestas (3)
Alfred.NESWADBA
Is you "square" defined by one polyline or 4 lines?
If it's one polyline you can offset the complete square contour to outer or inner side.
If it's defined by 4 lines you only can offset line-by-line ... or you use command _PEDIT and option _JOIN to get one polyline of the 4 lines.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
0 Me gusta
cadffm
Are you really sure that this is ONE polyline?
Select the square and look in PropertiesPalette(ctrl+1) for Objecttype (at the top)
Sebastian
0 Me gusta
imadHabash
also you can use RECTANG ( Rec ) command to get one attached polyline square elements .
Imad Habash
0 Me gusta
