Can i set minimum increments to Line Lengths While drawing
sebastianbmgoerner
sebastianbmgoerner
When drawing without typing in your desired distances, is it possible to somehow set the line length to a minimum increment, say round off to 10mm instead of me drawing lines that are 1824.2494mm long, insted have it limit itself to 1820mm?
Alfred.NESWADBA
For orthogonal lines you can define a grid/snap, but that does not help for all lines that are not vertical or horizontal.
AutoCAD does not have a setting for incremental-distance to define line-lengths.
Other question: when you know that the line has to be 1820 units long, why not entering the value? Either in the command-line or when dynamic mode is on on these fields?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
imadHabash
Simply ... the answer is NO !!
Imad Habash
Turn on snap mode (F9)
Kent1Cooper
... not just on, but of course with the Snap spacing set to the desired increment.  But as @Alfred.NESWADBA has pointed out, this will have the desired effect only for Lines drawn in orthogonal directions.
Kent Cooper, AIA
