Can I erase folder with old versions?
urigv
urigv
Good day to everyone,
For context, in my Windows PC I recently installed new versions of AutoCad 2022 (as well as Revit 2022). I found in a folder in C:\Autodesk where there are folders of old versions of this programs (Autocad 2018 and Revit 2020,2021) that take up a bunch of space. Is it safe to erase this folders and its content?
handjonathan
Hi @urigv
Thanks a lot for posting your question to the forums!   Yes, it is ok to remove these, but before you do, take a look here.
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
urigv
@handjonathan Thanks for the quick response! As the folders are from old versions that I no longer have installed (so no Repair or reinstall those), I can remove the folders with no issue. Saved up some space that I needed!
