Can I delete the spline inside the block without using the explode?
Can I delete the pline inside the block without using the explode?
cadffm
Hi.
Like every other edit to.
Open your Blockdefinition (use command BEDIT for example), use command ERASE or [DEL] to delete your spline, save the block, close the blockeditor, done.
Sebastian
