Can draw only horizontal and vertical lines
Message 1 of 10
Half way through a drawing I find that when I try to draw a line, it moves only horizontally or vertically as I move the cursor, although when I enter length and angle it does end up to those coordinates.  Up to now the line would follow the cursor wherever I moved it.  Have I pressed something inadvertently to cause this to happen?
Replies (9)
Message 2 of 10
user181
Try pressing F8 key to turn ortho off
Message 3 of 10
ennujozlagam
Hello,  i agree with @user181  just pressing F8 will do the trick. thanks
Message 4 of 10
BeKirra
Smiley Very Happy Agree with @user181 & @ennujozlagam
... and this may be added to your trick set if you just start to learn AutoCAD.
Click F8 key again to turn ortho back on.
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
Message 5 of 10
Tried F8, but the problem still persists. Others also suggested F8 so it must have been a clear option, but to no avail. Any other thoughts?Kind regards, Neil
Message 6 of 10
S.Faris
Is your SNAP on? Press F9 to Toggle
SALMANUL FARIS
Message 7 of 10
user181
When you press F8 does it say anything on the command line like <ortho on> or <ortho off>?  If not maybe it's the problem described HERE
You can also turn ortho on/off from the status bar. see image below.
Message 8 of 10
s.borello
It sounds like you need to turn ortho off... see link to screencast below to see how to do this.
https://autode.sk/2Tzft9T
Message 9 of 10
Problem solved. Shift 'O' turned off the Ortho Snap. F8 is totally dysfunctional, likely as a result of the computer set up disabling or setting the function keys to some other set of actions.Thanks to those who offered their help.
Message 10 of 10
hirahul1729
Community Visitor
Community Visitor
Thank you so much! I was just struggling with this issue as well.
