Can AutoCAD import a .CSV file?
I am currently trying to help a small surveying company do research on which AutoCAD package they need to purchase to do the limited things that they do. All I really need to know is if AutoCAD, not AutoCAD Civil3D, just straight up AutoCAD can import a .CSV file and place those points into model space?
dgorsman
Not directly, but it's reasonably easy to set up with scripting or LISP programming (provided you have the full version, NOT LT).  If you look around there's quite a few third party developers who can provide something more substantial.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
S.Faris
For sure, It can  be done. Here are a few methods;
Lisp : Survey Points Import and Create Free AutoLISP (LISP) for AutoCAD
Advanced Lisp Mehod : Point Manager
Something for the ANSII format : How to import a list of coordinates into AutoCAD
1 Dollar App Solution : Draw coordinates in AutoCAD from an Excel CSV file
SALMANUL FARIS
vladimir_michl
Alfred.NESWADBA
just with Excel formulas (to build an AutoCAD command based on your XYZ values)
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
