AutoCAD Forum
Can array in dynamic block spread arrayed items and add extra item as the object stretched?
3 REPLIES 3
merd94
296 Views, 3 Replies
Hello, I am creating a dynamic block (window) and stretching it, and I want to add subdividing elements (arrayed items) to it. I want the arrayed items to be divided evenly across the distance stretched and I want AutoCAD to add an extra object as I pass a specified distance. Is there a way to do it?
For example, the window distance is 550 cm, and the maximum distance for arrayed items I specify as 100 cm, which means there will be 6 arrayed items with a distance between arrayed items 91.6 (from 550/6), however, if I stretch the window to 600 cm AutoCAD should add one more arrayed item, and spread them evenly.
As I have tried everything that I know and searched forums, there is nothing related to this topic. And if there is no such thing, then dear Autodesk can you please add this simple formula to the dynamic blocks and make someone's life easier?
Merd.
Labels (2)
3 REPLIES 3
JBerns
in reply to: merd94
@merd94,
Dynamic Blocks (DB) being so specialized, they have their own forum.
You may want to post your question again or have the this Forum Admin move the question to the DB forum.
https://forums.autodesk.com/t5/dynamic-blocks-forum/bd-p/154
Jerry
CAD Administrator
Using Inventor 2022
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
merd94
in reply to: JBerns
Thank you, I will post there as well
JBerns
in reply to: merd94
Most welcome.
CAD Administrator
Using Inventor 2022
AutoCAD Inside the Factory
