Can an AutoCAD Architecture 2025 model export to a Revit file and keep the models intelligence.
Rpunturi
Rpunturi
Our company is being tasked more and more to create BIM building models. We have an AutoCAD 2D system that works well, and, in a nutshell, Revit is not ideal for our use.
AutoCAD Architecture may be just what we need. But the information on this program is thin.
Does AutoCAD Architecture 2025 create a BIM model that can be imported into the main Revit model while keeping its "System family" intelligence?
If so, is there a video or internet page I can refer to to understand how this task is done?
Thank you.
Ron
pendean
Community Legend
Community Legend
Not really: these are two very different programs, see a similar post from a couple of years ago, not much has changed
https://forums.autodesk.com/t5/revit-architecture-forum/convert-autocad-architecture-model-to-revit/...
BUT... do give it a try with your REVIT (or grab a trial version of REVIT to test) and your ACA DWG files to find out more.
David_W_Koch
In a word, no.
Revit cannot show AEC objects (Walls, Doors, etc.) in their native AutoCAD Architecture state.  You either have to turn on PROXYGRAPHICS or export a 3D view to AutoCAD and link that to Revit.  Either way, Revit will not see Walls, Doors, etc., let alone any intelligence present in AutoCAD Architecture.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Rpunturi
Thank you for your help.
