Calculating and dividing the equal amount of elements in Autocad
Hello everyone!
Recently, when I was preparing a technical drawing for solar power plant, I faced this problem. The layout consist of more than 100 000 solar panels which should be divided in a group of 600 each in order to allocate the inverter blocks. How can I divide the 100 000 solar panels into groups of 600 each? Is there a quick way of dividing into groups of numbers of items drawn?
Valentin-WSP
@Anonymous ,
Consider using the Rectangular Array command and the options on the ribbon.
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
devitg
What wide -to  high  ratio to divide
Maybe it is better to array by rectangle the 600 from the first panel , and then a new array from the 600 to get the 100000 or more .
Please upload your sample dwg
Here is the sample of array I need to divide. For the purpose of the layout I would like not to use the rectangular array because of its limited interaction and amendments option.
Patchy
Draw a constraints area of 600 panels and drag it around to match your layout?
devitg
@Anonymous Hi I made a test , guessing that panel where draw in a certain order, an it s so , but the are duplicated panels , they follow a certain order from down to up columns in left   to right  column.
I put the handle number in decimal format as to get an idea about how to gather the 600 panel .
Find attached dwg
Seem to be panel where array in four row , and some columns .
The first column is duplicated in each array  .
So it need to remove duplicated panels.
I do not remember the command to remove duplicated .
OVERKILL
