Anuncios
calculate vertical and horizontal polyline
No aplicable
Hi Everyone,
I was just wondering if there's any idea or lisp to calculate how many verticals and horizontals I have in my drawings.
layer in the same name. drawn in polyline, its frames for windows but I need to know how many I have frames in my project, verticals to be separated from horizontals, please note that this will be for entire high rise building.
I would appreciate if someone can give me any solutions, as it'll save me of time. if there's lisp program or any command.
best regards,
waseem
0 Me gusta
Responder
Soluciones aceptadas (4)
2.504 Vistas
45 Respuestas
Respuestas (45)
No aplicable
@ara_neresesian thank you, I will wait, let me know if you need more info about my drawings.
regards,
waseem
0 Me gusta
ara_neresesian
Solución aceptada
HI
Here it is, what you need just load the application bay "ap" and type  EL
the rest thing will do by the program.
but before everything i need to inform you
1- its primary program i need to   change something after your test.
2- this program works based on delta x  and current ucs
3- all polygons must be created from 4 point no more and closed,and in frame layer( just like what you have now in your drawing)
4- its working with  all objects inside the cad file, it can be change   if you want to select objects for calculate not all drawing.
5-Dont trust program, test it with your manual count in a few files,
6-if its was ok then you can use it.
use the program and tell me if its working well or not,
and if you need something more just let me know.
good luck
Kent1Cooper
Solución aceptada
@Anonymous wrote:
.... a lisp or command that give me how many vertical and horizontal I have with no sizes just quantities.
Here's another way, that builds in the restriction to 4-sided closed LWPolylines.
(defun C:HVFQ (/ ss n minpt maxpt LL UR delta hor ver); = Horizontal & Vertical Frame Quantities
  (if (setq ss (ssget "_X" '((0 . "LWPOLYLINE") (8 . "FRAME") (90 . 4) (-4 . "&") (70 . 1))))
    (progn ; then
      (repeat (setq n (sslength ss))
        (vla-getboundingbox (vlax-ename->vla-object  (ssname ss (setq n (1- n)))) 'minpt 'maxpt)
        (setq
          LL (vlax-safearray->list minpt)
          UR (vlax-safearray->list maxpt)
          delta (mapcar '- UR LL)
        ); setq
        (if (> (car delta) (cadr delta))
          (setq hor (1+ (cond (hor) (0))))
          (setq ver (1+ (cond (ver) (0))))
        ); if
      ); repeat
      (prompt (strcat "\n" (itoa hor) " horizontal, " (itoa ver) " vertical."))
    ); progn
  ); if
  (princ)
); defun
(vl-load-com)
Designed for orthogonal rectangular outlines as in your sample drawing, with the same questions as raised before:  would there ever be non-orthogonal angles, or curves, etc.?
Kent Cooper, AIA
0 Me gusta
No aplicable
@ara_neresesianthank you, I will test this program on different projects and let you know as soon as possible.
regards,
Waseem
0 Me gusta
No aplicable
@Kent1Cooperyour program is not working, perhaps your missing something.
regards
Waseem
0 Me gusta
Kent1Cooper
It works for me -- perhaps you are.  In your sample drawing attached to Message 19, I get:
Command: HVFQ
624 horizontal, 171 vertical.
QSELECT says there are 795 Polylines on the FRAME Layer, so that seems to add up.
Kent Cooper, AIA
0 Me gusta
No aplicable
@Kent1CooperI have tried it on different project, didn't work too
0 Me gusta
Kent1Cooper
"Didn't work" is never enough information.  Did it not load?  Did it load but the command name wasn't recognized?  Did it accept the command, but nothing happened?  Did something happen different from what you expected?  Did it report numbers but not correct numbers?  Were there any error messages?  Etc., etc.
Kent Cooper, AIA
0 Me gusta
No aplicable
@Kent1Cooperit loaded, when I typed the command it gave me this.
Assignment to protected symbol:
VER
enter break loop?
with selection yes/no
0 Me gusta
Kent1Cooper
VER
enter break loop?
Interesting that mine doesn't warn me about that....  There is a  (ver)  AutoLisp function that it's not allowing to be interfered with by using it as a variable name.  Change all instances of  ver  [by itself, not as part of longer words] in the code to  vert  instead, and try again.
Kent Cooper, AIA
0 Me gusta
cadffm
If you not load the code from the vlide..
VLide (open the file and use the [load window] button
or if you not set up the vlide to warn by assignment to protected symbols..
Tools
Environment options
General Options
SETQ to protected symbols
prompt to enter break loop
Sebastian
0 Me gusta
cadffm
Tools
Environment options
General Options
 Can not edit my original post, so i editing this quote
Sebastian
0 Me gusta
No aplicable
@ara_neresesianplease see attached, I identified all.
regards,
waseem
0 Me gusta
No aplicable
@Kent1Coopercan you send it to me as a file, not codes. so I upload it directly to the drawings
0 Me gusta
Kent1Cooper
Attached.
Kent Cooper, AIA
0 Me gusta
No aplicable
@Kent1Cooperit says unknown command. I don't know what's the problem
0 Me gusta
ara_neresesian
ok i got it,
yes its possible to count all of them in (top,  mid, bot) independently,
(but this one is a little complicated, )
so i am waiting to see what you want to add
and i will do all together
good luck
0 Me gusta
Kent1Cooper
Neither do I.  I tried it here, and it still works for me.  Exactly how are you loading it?
Kent Cooper, AIA
0 Me gusta
ara_neresesian
hi
do you something like this?
if yes what is it?
No aplicable
@ara_neresesian
yes I do
it'll be top and bottom
0 Me gusta
