Well, I got the "Too many objects selected for INTERSECT" taken care of. On Page 15 of GTCO CalComp DrawingBoard VI User's Guide, there is a section on "Selecting a Pre-Programmed Setup". I Config the Board to the Default which emulates the GTCO DP5 High Resolution Binary, afterwards the "Too many objects selected for INTERSECT" error did not occur after another attempted configuring the board to work with the Tablet Drawing.
However, the selection of command action still isn't working. There are two other saved Pre-Programmed Setup. One is an emulation Summagraphics MM 1201 B, which I don't think will work with this board. The other is CalComp 2000 ASCII emulation. I am going to that board configuration next. There is also some other setups for the board, CalComp 9100-1 through CalComp-4 and a CalComp AFT. There are other recommended settings for the board, one is for AutoCAD (DOS Only) Using the ADI format or the CalComp 9100 format, but both of these are for AutoCAD (DOS only), which is the Kurta Digitizer configuration and won't work because it is for DOS, not Windows based
AutoCAD. Their Troubleshooting Chart, under the topic "Unable to use the entire tablet surface". The first Cause is: "Incorrect format selected." Second Cause is: "Software application set up incorrectly." If the latter is true, then there will be no help from CalComp, because I have had that circular discussion with them insisting that it is all on AutoCAD, not their software nor the setting up of their board.
