CAD2022,Open the drawing and it prompts that the program "EwInitApp" is missing. How to solve it?
164624750
Observer Observer
164624750
Observer
Observer
I am using CAD2022. When I opened the drawing, it prompted that the program "EwInitApp" was missing.
Valentin_CAD
@164624750 ,
Consider a repair:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Observer
Observer
I have reinstalled many times with antivirus software turned off and also repaired many times, but none of them could solve the problem.
Valentin_CAD
@164624750 ,
Then perform the following:.
If the problem persist, then:
Emilio Valentin
pendean
Community Legend
Community Legend
@164624750 is the problem limits to one or a few files from a single source?
Or does this happen in all of your files, even if you start a new one?
EwInitApp is likely a 3rd party app the file really needs for you to see it's content,
or is an add-on you removed and did not load correctly in your 2022AutoCAD.
cadffm
You are talking about the proxynotive dialog message?
How to solve: I don't know about this application, so I can not know how to solve it.
Generally:
v1 - Sender/Creator should export the file as plain AutoCAD file (if this option is availalbe)
v2 - Install the ObjectEnabler (if available)
v3 - You can try to create a new file by using WBLOCK entire drawing or WBLOCK object selection,
        if it works, doublecheck that all objects are in the new file too.
Share this part about EwInitApp - I guess there are some words more about it, or?
Better: Share your DWG sample.
Sebastian
