Cad opens slowly from the server, opening seconds locally!!
No aplicable
Server 08 R2, LAN gigabit network, cad drawings is a Shared folder, open the cad drawings from the Shared folder, data transfer volume probably around 300 KB, but on the local open the drawing close to seconds.There is no problem with the network cable. Put the file on the server for tens of M/ s, but only open the cad drawing slowly.Often use cad antivirus software, as always. I forgot to mention that the cad version is 2010(a good friend of mine said that he had the same problem with the 2012 version in other companies, and only the 2008 version would not have this problem).
0 Me gusta
Responder
481 Vistas
5 Respuestas
Respuestas (5)
TheCADnoob
0 Me gusta
john.vellek
HI @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
 It sounds like you have a mixture of older software in this environment.  Because of the server version, I assume that the storage is likely some sort of RAID in the server itself and not an external store such as NAS or SAN.
I would first use your RAID utility ti verify that the assembly is working properly and that no portion of the RAID has errors.
Then, I would construct a new File share with full permissions.  Manually map a drive to this share on the client side. Copy a CAD project there and see if you are still seeing errors.
What is the operating system on the client side?
John Vellek
0 Me gusta
No aplicable
The server is raid5. The user has full control permissions in the shared folder. Whether it has full control permissions or only read-only control permissions will open very slowly, but the 2008 version of cad alone will not have this situation, the client's system Basically all win7, 64-bit system, the strange thing is that at the beginning reinstall the system will not have this problem, after a period of time will have this problem, I suspect that the cad virus caused, but I have used I can find cad anti-virus software to kill the virus, still have this problem, and this problem is not only my company has this problem, as far as I understand that many people have this problem
0 Me gusta
No aplicable
The server is in accordance with the 2008 R2 version of the server system, configured raid5
0 Me gusta
john.vellek
Hi @Anonymous,Thanks for the confirmation on the hardware configuration. Please try the steps I suggested and report back with the results.
On the client side, you might also run with a Diagnostic startup (MSCONFIG) to turn off everything possible to see if there are any conflicts.  Try turning off (temporarily) the UAC, and security software and the Windows Firewall.
John Vellek
0 Me gusta
