AutoCAD Forum
CAD Blocks disappear after pasting in a document !!
2 REPLIES 2
georgia.medcalfWLXFQ
2104 Views, 2 Replies
Hi all,
I'm new to autocad and am having issues with trying to transfer/past over some preexisting cadblock objects. I can open them in a new document perfectly but when I copy and paste them into my existing document some of them are disappearing. Please see images attached.
I'm not sure if this is a layering issue or if I need to make adjustments to my existing file. If anyone knows please advise as I cannot proceed with my work until this is resolved.
Thanks in advance,
GM
Labels (4)
2 REPLIES 2
Hi and welcome to AutoCAD Forum,
then it's not a paste problem !! your successfully pasted objects not appear , right ?
either you have a Layer or Scale problem issue . i mean that you have to turn ON all layers and/or thaw all layers ( LAYON and LAYTHW command ) . also you may have a duplicate block name , before pasting check existing block names that you don't have the same name for a different blocks. we can not know without your CAD dwg ?
Imad Habash
LAYON seemed to be the correct resolution. Thanks for your help 🙂
Forma Design Contest
