CAD 3D Corner Piece
Dsavvy
CAD 3D Corner Piece
Dsavvy
Anyone know how I can make this 3D piece with a 90° corner return? Basically a molding wrapped around a corner
0 Me gusta
Responder
Soluciones aceptadas (3)
462 Vistas
5 Respuestas
Respuestas (5)
Kent1Cooper
SLICE a 45° wedge off the end.  MIRROR in an appropriately defined UCS.  UNION if you want.
Kent Cooper, AIA
0 Me gusta
Dsavvy
No idea how to slice a 45° angle :cara_sonriente_con_la_boca_abierta_y_los_ojos_cerrados:. Can you show me please? I attached it
0 Me gusta
Patchy
Solución aceptada
Make 2 pieces and put together at 90 degrees, draw 2 lines at 45 degrees and use them as cutting plane to slice.
Pick end points of one line and 1 end point of the other line.
0 Me gusta
j.palmeL29YX
Solución aceptada
>>Click<<
or
>>Click<<
Jürgen Palme
0 Me gusta
Kent1Cooper
Solución aceptada
It can be done easily enough without actually drawing Lines for the purpose.  Either by setting a UCS or by 3D Rotating in the WCS, get to the point where the Z axis aims upward from the top:
In PLAN view so that you're looking down from above:
SLICE
{select the 3D Solid, Enter to complete selection}
{pick some point A}
@Anonymous,10 {to get point B -- does not need to be beyond the other side, but anywhere in 45° relation to A}
@0,0,1 {third point for Slicing plane}
{pick to the right to keep that part}
MIRROR
{you know what to do}
Kent Cooper, AIA
0 Me gusta
