Bulk edit point labels
No aplicable
Is there any way to bulk edit point labels? I have 700 labels that need to be changed from existing to new value. Is there a way to upload a spreadsheet and change that way?
0 Me gusta
Responder
Soluciones aceptadas (1)
358 Vistas
2 Respuestas
Respuestas (2)
Alfred.NESWADBA
Solución aceptada
If that objects are blocks with attributes then you can use command ATTOUT and ATTIN to export the attribute values, then modify them in e.g. Excel and then re-import the modified values into your AutoCAD drawing.
Some details to be found >>>here<<<.
If "point labels" is anything else, then please let us know which type of object these items are.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
No aplicable
Thank you! New to AutoCAD and this is very helpful.
0 Me gusta
