Bug: Undoing after CUI edit will undock the command line - Autocad MEP 2025
dsummersPEG
dsummersPEG
Reporting another bug. After I edit the CUI, if I select Undo, Autocad undocks the commandline. I am running Autocad MEP 2025. Relocate this or whatever, I do not care anymore.
@dsummersPEG Your post title was modified to add the product name and version and moved to the AutoCAD MEP forum to increase findability - CGBenner
pendean
Community Legend
Community Legend
@dsummersPEG use WSSAVE command to save the state your of active workspace they way you want it to always be, then do your CUI edit.
It appears you've never used that command and CUI is just restoring it's saved state (where you don't want toe commandline).
ChicagoLooper
Try this:
LOCKUI=>2
Chicagolooper
